the small one is to get on trosserobotics.
friends and robots ,what more do you need
Hello everyone, what kind of Phillips screw driver do I need to dissassemble my V2? Thanks.
Sega Dreamcast>Everyothervideogameconsoleever
http://www.trossenrobotics.com/p/JIS-Japanese-Industrial-Standard-Scredriver-Set.aspx
here a set from trossenrobotics
What do you do when the screws are so tight you can't undo them?
The cure for this disease is lack of money. It doesn't stop the itch though.
hi all,take a mini gripper or drill them out carefull
Then what? How do I get replacement screws? It isn't my robot either.
Hey Nomad iDrum, I didn't realize you guys were on! I just finished breakfast. I have two screws which are really tight as well. the screw driver turns in them but the screw doesn't turn with it. I guess I will try out a gripper.
this is also good way to it unscrewd
steel bits or a bendeble screwdriver for bits.
these are bits and normal small ring key.you find them in box.
cost about 10 dollar
Okay. These will help me get those screws?
these are bendeble,the middle section is bendeblle. http://www.amazon.co.uk/150mm-Flexible-Screwdriver-Extension-Adaptor/dp/B00419O0Y8
yes these do the trick,or very long screwdriver
