A hydraulic manifold assembly
1 post / 0 new
lucky
lucky's picture
I search the Internet and find some information.A hydraulic manifold assembly for use in
 a hydraulic release system operable to control a spring applied, hydraulically released
 parking brake assembly, includes a manifold block and a manually operated hydraulic
 lock valve assembled in the manifold block. The manifold block includes a high pressure
 inlet port, an actuator port for connection to a brake release actuator, an outlet port for
 connecting to a hydraulic fluid reservoir, and an internal passage connecting an actuator
port to the outlet port. The manually operated lock valve is manually movable between
 an open position allowing flow of hydraulic fluid from the actuator port to outlet port and
a closed position blocking flow of hydraulic fluid from the actuator port to the outlet port,
the hydraulic lock valve in its closed position containing pressurized fluid in the actuator
 to keep the brake released.
This is the background of the invention.Many vehicles heretofore have employed
 spring-applied, hydraulically-released (SAHR) parking brake systems. In these systems, a brake such as shoe
assembly or a disk assembly is engaged under the force of a spring which permanently
 biases thebrake towards its applied or engaged position. The brake is released by
hydraulic pressure generated by a pump driven directly or indirectly by the vehicle's
engine.
