Learn about scoring Forum's Raw Score: 34858.0
September 6, 2010 09:52 AM
Categories: Rovio
ASJBR
I can connect to my rovio and control it but i cannot see the the camara on my laptop. Unspecified Error line 399 Char 13  Rovio .js code 0
any suggestions? what am i doing wrong?
Discussion:    Add a Comment | Comments 1-6 of 6 | Latest Comment
September 8, 2010 4:05 PM
This could be a browser issue. What are you running on your laptop?
September 9, 2010 5:15 AM
I had the same problem getting rovio to show up. I had to install firefox as i was using internet explorer before. Worked for me fine after the install.
September 9, 2010 1:17 PM
I am using IE 8. seems to work fine with the same browser on my desktop. anybody have any suggestions as to any tweaking i need to do on the laptop?
Regards,
ar
September 9, 2010 2:03 PM
Only thing I can think of is the active x components need to be installed. It's easy to miss the warning banner at the top of the browser pane, I guess Mr Gates is more astute than us mere mortals. I can bring up the Rovio console on both my Android phone and my works computer but neither will display the video stream. The work server blocks the video but haven't worked out what causes the issue with the Android app.
My laptop works ok though (from Starbucks anyway) but only after I enabled the activeX.
Regards,
NAt.
September 9, 2010 2:19 PM
hmm..enable Active X..i do remember seeing the banner and went ahead and what i thought was enabled Active X. where can go to reenable Active X. seems like you're on to something here.
Thank you very much for your help.
Regards,
ar
September 9, 2010 2:31 PM
If you try to access Rovio from the laptop again, it should come up with the same banner. Just click the banner and select install from the drop down menu that appears. It'll download and then you have to log out and back into Rovio. That should sort it.
Good luck.
Discussion:    Add a Comment | Back to Top | Comments 1-6 of 6 | Latest Comment
