OUR NETWORK:TouchSmart Community TechLore Sling Community MyOpenRouter MediaSmart home Pogoplugged See all... About UsAdvertiseContact Us
Learn about scoring Forum's Raw Score: 218157.0
January 5, 2009 12:34 PM
Categories: Rovio
punkouter
I would like to be able to talk to people in the room using that.. anyone come up with anything like that?
I would imagine it would just invovle some .exe that would run the txt2speech API and create a wave and then somehow send it to the rovio  ?
Discussion:    Add a Comment | Comments 1-6 of 6 | Latest Comment
January 5, 2009 1:05 PM
I've done this using MSs speech API in C#. When I get a minute I'll post some source code.
January 5, 2009 1:29 PM
From the API:
Other - GetAudio.cgi
Description
Send audio to server and playback at server side
Grammar
/GetAudio.cgi
The data flow is from client to IPCam, which is different from GetData.cgi.
The audio data must be send with HTTP POST method.
Audio format: 16bit PCM, 8000Hz
Should be able to do this with this information. Looks like the last poster has figured it out. I look forward to his C# code. I'm going to have to do this too. (Rovio yelling "Help Me!" if it gets stuck?)
January 5, 2009 4:18 PM
This works. The audio is very soft so it needs to be boosted, but maybe one of you guys can figure that out and repost a better example.
private void Say(string text)
try
_rovioAudioSocket = new Socket(AddressFamily.InterNetwork, SocketType.Stream, ProtocolType.Tcp);
System.Net.IPEndPoint remoteEndPoint = new System.Net.IPEndPoint(System.Net.IPAddress.Parse(_rovioIPAddress), _rovioAudioPort);
_rovioAudioSocket.Connect(remoteEndPoint);
textBox1.AppendText(DateTime.Now.ToString() + " : Audio socket connected\r\n");
// Prepare the audio port for sending audio from the PC back to the Rovio
string temp = "POST /GetAudio.cgi HTTP/1.1\r\n" + "User-Agent: AudioAgent\r\n" + "Host: " + _rovioIPAddress + "\r\n" + "Content-Length: 2147483647\r\n" + "Cache-Control: no-cache\r\n" + "\r\n";
szSend = StringToByteArray(temp);
//REVIEW: skipping Credentials
if (_rovioAudioSocket.Send(szSend) == -1)
textBox1.AppendText(DateTime.Now.ToString() + " : Error sending initial packet\r\n");
Stream stream = new MemoryStream();
byte[] format = new byte[0];
speaker.SetOutputToAudioStream(stream, new SpeechAudioFormatInfo(8000, AudioBitsPerSample.Sixteen, AudioChannel.Mono));
speaker.Volume = 100;
speaker.Rate = -8;
speaker.Speak(text);
stream.Seek(0, SeekOrigin.Begin);
byte[] output = new byte[stream.Length];
stream.Read(output, 0, (int)stream.Length);
_rovioAudioSocket.Send(output);
_rovioAudioSocket.Close();
textBox1.AppendText(DateTime.Now.ToString() + " : Audio socket closed\r\n");
catch (Exception ex)
textBox1.AppendText(DateTime.Now + " :: " + ex.Message.ToString() + "\r\n");
January 8, 2009 12:49 PM
Have any app I could have doing this ?
View unverified member's comment - posted by The Cpp
January 31, 2009 4:45 PM
This is just the port you have assigned for communicating with the Rovio (80 by default).
Discussion:    Add a Comment | Back to Top | Comments 1-6 of 6 | Latest Comment
