Learn about scoring Forum's Raw Score: 7725450.0
December 18, 2008 12:04 PM
Categories: Rovio
Rating (1 votes)
Administrator
Hello everyone,
We're excited to announce that WowWee is looking for additional beta testers for the newest version of the Rovio firmware, 5.00b7.
You can snag this version of the firmware in our downloads area by clicking here.
Once you get a chance to test the new firmware, please come back to this thread and post your feedback for WowWee.  We'd love to hear how the installation process goes and all the details of how the new firmware works for you.
Looking forward to the results and your contributions to making Rovio the best it can be, happy testing!
Administrator
Blog | Twitter
Discussion:    Add a Comment | Comments 51-75 of 255 | Latest Comment | « Previous 1 2 3 4 5 611 Next »
December 21, 2008 1:59 PM
I found updating the Network settings with Safari (Apple browser for windows) I had less problems. It feezes sometimes after the 30 sec reboot countdown but not everytime. When it does freeze I reboot Rovio and reopen the browser page.
Rovio User Group
Come into the room and I will see if I can help you
Paltalk ID:ramzez1974
http://www.robocommunity.com/forum/thread/14882
December 22, 2008 3:30 AM
Fraggboy said:
TLVR said: Using Internet Explorer browser version 7.0.6001.18000 (for Windows Vista): -BAD results: No Video I hope this helps. Smile
Did the previous firmware work in IE for you?  When I upgraded to the new firmware, I received the red "X" for a few times. I had to refresh the screen until I received the download and install Active X box.  After that IE works great.
The previous firmware (version 4.09 beta) didn't work in IE (7.0.6001.18000) for me.
Only the stable version (version 3.97) works fine.
Is your Operating System VISTA SP1?
December 22, 2008 4:57 AM
For me the 4.09beta works fine in IE7 (7.0.2900.2180).
Used a lot on an XP+SP3 partition because I was the only way to use audio.
December 22, 2008 7:41 AM updated: December 22, 2008 8:10 AM
USER access is not working correctly.
Has any one tried to ceate just a USER access? As long as I have Admin access I can use Rovio as intended woth little problem. If I login with only USER access rights all I get is the camera and video, the movement controls do not work.
I use IE 7 on a PC, and no-ip.com to access rovio, I also have this problem over the lan inside the house.
December 22, 2008 8:05 AM
I have the same issue with mine. When I access Rovio across the Internet I am alway prompted for a user name and password. I enter the users name and password for the non-admin user but Rovio is actually asking for the Admin name and password.
Using Safari on my PowerBook running 10.5.6 results in Safari sucking most of my CPU power and making the PowerBook unresponsive or so slow to respond as to be unusable. Using Firefox 3.0.5 on my MacBook seems to work without killing the CPU on my MacBook.
December 22, 2008 9:12 AM
Here is a thought. It would be nice to have a way to shut down rovio from across the room. You know for those moments in life the world doesn't need to see. What about an update that uses the WowWee Roboremote to turn Rovios eyes and ears off. It would also be great to have Rovio play a sound for each individual user that logs in.
December 22, 2008 1:49 PM updated: December 22, 2008 2:05 PM
Never used the admin, I'm using my usual Giobatta user and works fine, both inside the LAN and outside, but I changed the password for the admin, actually I'm using the same pwd for both the accounts, maybe it is for that reason it works?
same here, reported some posts ago, both the cores of the iMac are at 80% using Safari 3.2.1, but I noticed also a faster framerate in Safari (atm I'm using 640x480 without lag, outside the network)
not tryied Firefox yet, the video quality and brightness are identical to Safari (I read on Windows this change a lot depending of the browser) ?
December 22, 2008 2:20 PM
Did the Update, everything configured fine. But my rovio stutters now. It hesitates to move forward at times on both local and external networks.
For Technology News, Some tools and Information goto http://cmilian.spaces.live.com
December 22, 2008 2:41 PM
Mine did he same. I switched back to 3.97 and 4.09 and no problems with stutter. Which router are you using? I have Buffalo WHR-G54S. I also have tried using Apple Safari and I think the stutter is worse. IE7 seems to work better.
Rovio Commander II
Record Video, Motion Detect, Sentry Paths and more. All features built in. <br>
http://www.robocommunity.com/download/15769/_New-Rovio-Commander-II/
December 22, 2008 2:59 PM
I am using Vista 64 Bit, IE 7.0.6 and My router is a Belkin F5D8233 N Router
December 22, 2008 4:46 PM
Hey I hot the new firmware working but only on wep. If I enable wpa on router do I just run setup software on pc to connect to wpa? I Have tried and it simply won't work
Can anyone here tell me how they connected via wpa I.e the steps taken?
December 22, 2008 5:10 PM updated: December 22, 2008 5:37 PM
dj_siek said: Hey I hot the new firmware working but only on wep. If I enable wpa on router do I just run setup software on pc to connect to wpa? I Have tried and it simply won't work Can anyone here tell me how they connected via wpa I.e the steps taken? Thanks
I don't use WPA2, just WPA for Rovio.  My laptops use WPA2.  Rovio has a separate SSID.  In the picture, you can see my settings.  The key setting is Auto.  I have some of my logs filtered, so I don't know if Rovio uses TKIP, or AES.  My laptops and other wireless goodies connect via TKIP (More secure than AES).
On Rovio I just put in the WPA password.  Nothing else to do on Rovio. It's mostly configured on your firewall..
December 22, 2008 5:26 PM
Hi, can i know please why don't you just use MAC-Filter security and you need WPA, WPA2?
Best regards,
JPapavas
______________________________________________
WowWee Thank you :)
December 22, 2008 5:35 PM
jpapavas said: Hi, can i know please why don't you just use MAC-Filter security and you need WPA, WPA2? Best regards, JPapavas
I do use MAC address filtering with WPA2! A person shouldn't use that alone.   One can use software to change their MAC address.  There are tools out there to sniff for a MAC address.  If a person only uses that for security, they might as well run an open system.
 When you get a second, I suggest you read up how easy it is to perform
http://blogs.techrepublic.com.com/security/?p=395
December 23, 2008 1:23 PM
Yes, but a device see if you got the MAC address that has access and
lets you log in to the network.
There is no broadcast MAC address list so someone can "sniff" or any other way, everything happens from the device (AP) internal, so if you got athorization you can login.
The only way is if with UTP cable try to connect, he knows the administrator Password and login to the WEB interface and add the MAC Address alone.
By the way if i did see someone inside my network i will call him home to get a drink or a coffee and tell me how he done it.
By the way don't mess the WEP key with all the others.
WowWee Thank you :)
December 23, 2008 3:17 PM updated: December 23, 2008 3:18 PM
Ahhh.... using a wireless network, your MAC address is broadcast to anyone in range (think about it, how does your laptop tell the AP that it is authorized?). All an attack needs to do is sit back and monitor the traffic, then either wait until you stop broadcasting, or knock you offline, and then spoof your MAC to gain total access (spoof as is get his network card to pretend to have your MAC address, which as has been mentioned, is fairly easy to do).
Not to mention that without some form of encryption, an attacker can monitor and record all of you traffic (including any unencrypted usernames/passwords you use to log in to various sites) without having to compromise your network.
I used to have great fun with unsecured networks, I had a little program that would sniff local traffic, and display any images that were transferred.
December 23, 2008 5:31 PM
Updated and have the following issues:
Freezes/knocks me off when docking. When I drive the rovio and it docks the video freezes and I have to reload IE, does not happen in Firefox..but that's moot as I get no sound either way in Firefox.
Screen on IE is messed up. The Audio/Video/light etc section is displaying way down the page where you can't see it...have to scroll down to get to it, does not have this problem in firefox.
December 23, 2008 10:47 PM updated: December 23, 2008 10:48 PM
I do use MAC address filtering with WPA2! A person shouldn't use that alone.� �  One can use software to change their MAC address.�  There are tools out there to sniff for a MAC address.�  If a person only uses that for security, they might as well run an open system.�
� When you get a second, I suggest you read up how easy it is to perform
Mac filtering is like hiding your SSID, it doesn't really stop anyone from getting on your network, but it makes you feel like you're really protecting your wireless network.
It's trivial to spoof your MAC address and get the SSID someone is trying to hide. You either wait until someone connects to the wireless network, or force a disassociation from a connected station. When the disassociated station connects again.....Presto!!! There's the hidden SSID broadcast to anyone who's sniffing the network. That's because even the authorized stations need to know the SSID to get connected and the AP will broadcast it as required.
Several tools are available to sniff your network passively and you'll never know they're there. WEP is already cracked and basically useless. WPA was recently cracked, but not totally so you're still pretty safe using WPA or WPA2.
December 24, 2008 12:40 PM updated: December 24, 2008 12:49 PM
I am using
firmware 5.00b7
IE browser 6.0.2900.5512.xpsp_sp3_gdr.
WinXP Pro SP3
Whenever i change my video settings my Mic TO THE rovio stops working but i can still hear the from the rovio... when i adjust either the mic or speaker volume on the rovio then all of a sudden my mic to the rovio works again
Also out of no where my rovio started doing the thing where when going forward it is not smooth... it kinda seems like im pressing he the forward arrow button real fast.......
wierd thing is that the rovio didnt do this when i first updated the firmware it just started doing this now.... maybe its out of battery but it shows 3 out of 4 sticks on the battery life so unless the battery meter is wrong i dont know...
and before i forget ... MERRY CHRISTMAS
Thanks in Advance
Eddie
December 24, 2008 12:44 PM
hey guys..... have a nice xmas!!! :-)
December 24, 2008 1:51 PM
Merry XMAS !!!!
I hope you get all your needed robotic hardware under the tree !!!!
December 25, 2008 2:23 AM updated: December 25, 2008 10:27 AM
Bad interface for IE in new firmware V5.00b7
Moderator Edit to resize pictures so that they don't bust the thread formatting. Use a RightMouseButton-ViewImage to see the full size that is linked into the thread.
December 25, 2008 4:56 AM
I had that also. What I had to do is to reboot Rovio. That cleared my screen up.
December 25, 2008 10:53 AM
I split off a discussion started here about trouble connecting a Rovio.
It's now in this other thread.
http://www.robocommunity.com/forum/thread/14918/Trouble-Connecting-Rovio/
ScottE -- collecting and building robots for 40 years - details in profile
December 25, 2008 8:10 PM
I got for christmas a new rovio. The video suddenly drops for no reason. I tried rebooting the rovio, but it did not fix the issue.
I upgraded the latest firmware. I have not observe any issues. But the problem with the video suddenly dropping still happens. The video dropping happens both in the internal and external internet. For no reason at all the video comes back after a while.
Can anybody help what the problem mybe?
Tomasito
Discussion:    Add a Comment | Back to Top | Comments 51-75 of 255 | Latest Comment | « Previous 1 2 3 4 5 611 Next »
