Learn about scoring Forum's Raw Score: 216311.0
April 11, 2008 07:37 PM
Categories: Bladestar
NataZ
Hello there, just wondering what your experience with the baldestar has been, mine doesn't seem to respond much to the controls, I undestand that it's not going to be a fast response but sometimes I can keep the buttons pressed for 5 seconds and nothing happens, same with elevation, if I leave it alone it just hovers isn't it supposed to roam...
Also battery time is aroud 3-4min, I'm using rechargeables so this could be a factor here (7.2V as opposed to 9V).
Could I have a defective unit or U guys think if I just replace the batteries with regular duracel/energyzer it would improve the performance? I've used this same batteries with my Dragon Fly and 2 small Heli's with no problems...
Discussion:    Add a Comment | Comments 1-3 of 3 | Latest Comment
April 13, 2008 4:48 AM
try the 9v Duracell batteries & see if you get a more responsive Bladestar. Generally it's not a good idea  to use batteries with voltage ratings much lower than what's listed on the equipment.
July 23, 2008 5:38 PM
i think that bladestar is a waste of money
August 9, 2008 11:56 PM
I think 'roaming' just occurs naturally from the air flow in a room. When you press a directional button does the Bladestar start making a different running noise? That indicates the propellers pulsing and trying to make it move where you're directing it.
You also want to be sure to point the control right at the bladestar, it seems to have a very limited viewing range of it. Also I think that when it in contact with it's controller the inner light stays lit, when it loses contact it starts to flash.
