April 10, 2008 8:54 PM
Yeah, it should work on a breadboard. If nothing else you may want to whip up a cable for it instead of plugging it directly in to the board, that way you can tweak on it's position and such.
I think p-basic is the programming language, isn't it? (anyone, correct me if I'm wrong) The breadboard is just the layer between the processor and the other bits (sensors, lights, motor controllers, etc...). Some developer kits include some kind of breadboard (BOE), others are designed to plug into the top of a standard breadboard (Freeduino). Some just have plain old headers sticking out that you can plug jumper wires into (like the Arduino).
Any standard sized DIP chip should plug into the center of a breadboard. However, you probably want to start with a package/kit of some sort, instead of individual components. As linked above, I chose the Arduino setup, which is basically just the processor and a power supply. If you want PBasic or a full robot kit, try something like this. It includes all the parts you need to build, program, and start using a basic wheeled robot, and is fairly upgradeable as you learn more (the PING sensor you linked earlier can be added to the BoeBot fairly easily).
edit: Good looking out RebelTaz!
