By off do you mean sleep mode or power down?
Keep the robotic dreams,
-BG
what are roboquad's functions?
-BG
I just tested it and it seems that whenever you hold its back legs down it does it.
View unverified member's comment - posted by roboquad248
His functions? Here.
- 4 layer, full function, illuminated remote control
- 72 pre-programmed functions
- 4 modes
- direct control
- autonomous
- guard: visually scans the environment; sound sensor detects noise
- sleep: enters sleep mode after 5 minutes, powers down after 24 hours
- 2 built in demos: dance and movement
- Programmable: up to 40 moves
- Sleek and agile: rotating legs, articulated neck
- Advanced movement control
- control direction
- control style of walking (i.e., crab walk, stomp walk, rotation walking)
- control head movements
- Light sensor: headlights turn on and off and Roboquad will react depending upon ambient light levels
- Sound sensor: reacts to sounds and scans for nearest object when disturbed (when stationary)
- Autonomous mode
- interacts with his environment as he moves through it, scanning and avoiding obstacles
- behavior influenced by 3 controllable personality settings
- Activity level
- Aggression level
- Awareness level
- Deep IR scanner vision system
- multiple scanning ranges
- used to assess distances and obstacles and influence behavior
- 5 scanning sequences
- Smart scan: examines surroundings then reacts if anything changes; reacts according to aggression and activity levels
- Scan left and scan right: will turn and face any object within a 3 foot range, on his left or right side
- Approach nearest object: looks left and right while ramping up the scanning range and moves towards the closest object found
- escape walk: will select the largest open space and move toward it
- flinch response: if an object approaches his scanner very quickly he will react, according to his aggression level
-Volume control
Keep the robotic dreams alive,
-BG
Visit my site at http://www.bgweb.webs.com/
