Learn about scoring Forum's Raw Score: 41671.2
March 17, 2008 07:14 PM
Categories: Other WowWee Robots
VanMan
I recently found out that The Source was selling robopet on clearance, so I tracked down 1 locally.
It was a display model that was all beat up and dirty. The rear right leg moves by itself without the inside motor moving, so I figure that the connection to the motor on the inside broke.
When I turn it on, that rear right motor activates, but doesn't engage the leg.
So I'm trying to open it up to see how I might be able to fix it, but 2 of the screws heads are stripped somewhat (I think the Radio Shack (Source) guys tried to do the same), and can't get them to undo.
Has anyone had this problem with a leg motor connection, or can give advice on undoing a screw with a stripped head?
 Thanks.
 Other than that, the robopet looks pretty good actually. The skeletal leg appearance is growing on me.
Discussion:    Add a Comment | Comments 1-3 of 3 | Latest Comment
March 19, 2008 6:55 PM
Ok, well, I opened up it, and then opened up the motor casing and found that a gear had 3 broken teeth. I rotated the gear to allow good teeth to be used. I had to make it fit into the leg by shaving off some stuff to get the square part into the leg right.
Anyway, seems to be working. I still hear something spinning sometimes, but the leg in questions seems to be doing what it needs to do.
March 19, 2008 7:21 PM
Interesting, I don't supppose you took any photo's while you were fixing it?
March 20, 2008 4:18 AM
I didn't, but now when the left leg gets too far forward, there's clicking coming from the motor, so I might be facing the same problem.
I'll be opening it up to check the left rear leg, so I'll take pics.
