Learn about scoring Forum's Raw Score: 1257640.0
February 28, 2008 05:02 PM
Categories: General Robotics
DrNeff
Does anyone know of a source for the Tamiya style mini battery connectors that are used on the I-Cybie? They are three pin connectors. The battey connects with three leads providing 6 & 12 volts The charger only need two of the pin connections. Hours of Google searches have turned up nothing. Any help would be greatly appreciated.
Discussion:    Add a Comment | Comments 1-25 of 31 | Latest Comment | 1 2 Next »
February 28, 2008 7:31 PM
Look under Tamiya and see if those are what you need.
http://www3.towerhobbies.com/cgi-bin/WTI0095P?FVSEARCH=tamiya+connector&s...
http://www3.omnimodels.com/cgi-bin/WOI0095P?FVSEARCH=tamiya+connector&sea...
Mudbugnla
Wowwee Bots: Robosapien V1 and V2, RoboQuad, Robotyrannus, RoboReptile, RoboPet, Tribot
Tomy Bots: Verbot, I-Sobot
Meccano Bots: Spykee
RoboBrothers: RoboPHILO
February 28, 2008 7:40 PM
Thanks for the help. Unfortunately those suppliers only have the two wire connectors. Never thought a mini three wire one would be so hard to find.
February 28, 2008 7:52 PM
Could you post a picture of the plug? A closeup view.
Mudbugnla
February 29, 2008 12:44 PM
Here are the I-Cybie battery connectors.
The sections measures about 31/32"L x 7/32"h x 5/8"w
I-Cybie connector2I-Cybie Connectors 2
February 29, 2008 12:49 PM
I see the three pins on your connector, but are you using all three pins for power or just two? If you cannot find these connectors you could just solder some mini connectors from another namebrand.
Look at these:
http://www.allelectronics.com/cgi-bin/category/189/Connectors_(Multi_Pin).html
Mudbugnla
February 29, 2008 1:25 PM
All three connectors are being used. The battery pack is a ten cell 12volt that is tapped at the center. The robot requires the 6/12v output. The charger lead only has to use the outer connectors. The battery pack is only rated at 800mah which results in a very short run time.
I am looking for the exact replacement connectors because I'm building two 2300ahm battery packs for the I-Cybie and also need the connector for the smart battery charger that will be used with them. Because of the limited space in the battery compartment the connectors must be small. I have been unable to find anything even similar to these connectors.
The only place I have seen the connectors is on a battery pack that is manufactured in the UK. I wrote to the seller and was told that they buy them by the 1000s. They offered to tell me the make and model upon request but so far my request remains unanswered.
February 29, 2008 3:48 PM
Take a look at Deans connectors. You can also try MOLEX connectors. You could just cut off the originals and use mini MOLEX.
Deans
http://www.hobbypeople.net/gallery/625083.asp
MOLEX
http://www.google.com/products?hl=en&q=molex+connectors&um=1&ie=U...
Mini
http://www.hobbylinc.com/htm/mtr/mtr5000401.htm?source=froogle
Mudbugnla
February 29, 2008 4:25 PM
Thanks again for your help.
I was really hoping to find a Tamiya type set of connectors, but the Deans and the Molex certainly offer good alternate possibilities.
February 29, 2008 4:37 PM
Check out these..I believe these would work if you cannot find the Tamiya jacks. each has a male and female on each end which you could cut and splice. Also check out their two-wire sets which actually have three wires.
http://www.commonsenserc.com/product_info.php?cPath=32_39&products_id=283
Here is the entire list
http://www.commonsenserc.com/index.php?cPath=32_39
Mudbugnla
March 5, 2008 1:26 PM
Don't know about the connector but it did look familiar. Maybe Jameco would have that one.
Your question brought up a humorous memory though. Back in the 70's I was an electronics tech at a local audio tv repair shop. One day a young fellow came into the store and wanted a male phono plug and jack bought it and left. About a half hour later he came back in and his handswere trembling and wanted to know what would be a good power connector for his new cassette deck he had just installed in his car. He wanted a quick disconnect as he wanted to remove it every time he left his car. Theft prevention I guess. Well...the story was that he had tried to hook the 12 volt dc power to his deck using the phono jack and plug with explosive results!! Dead short when he plugged it in and burned the connector badly with a bang! Got him a two pin polarized connector set and he was on his way. Just had to pass this along. :-)
Paul
August 10, 2008 10:15 AM
Dr. Neff, Did you ever find the charger you were looking for? I have the same need and I was curious as to how you made out. Thanks.
October 6, 2008 9:36 AM
*** Deleted By Moderator ***
December 3, 2008 8:54 AM
Once you get the battery packs built, how are you going to charge them? I don't think the i-cybie charger can charge the higher current batteries.
December 3, 2008 10:01 AM
It's not clear who you are asking, or whether they still visit the community.
The author of the thread has not visited since June.
The person asking for a followup hasn't visited since August.
ScottE -- collecting and building robots for 40 years - details in profile
January 26, 2009 11:08 PM
We are mainly in the RC field but if there are connectors or adapters that you guys need, let us know. We can provide any type.
Mike
www.CommonSenseRC.com
January 29, 2009 12:00 AM
Mikekomm said: We are mainly in the RC field but if there are connectors or adapters that you guys need, let us know. We can provide any type. Mike www.CommonSenseRC.com
Ok... how about contacts? Something along the lines of this:
Derek Tombrello
www.RobotsAndComputers.com
May 22, 2009 1:47 AM updated: May 26, 2009 4:21 AM
Check out these sites.
http://www.souriau.com/index.php?id=524
http://www.souriau-industrial.com/en/product_ranges_overview
June 1, 2009 6:00 PM updated: June 1, 2009 6:09 PM
Silverlit still has their i-cybie store online via http://www.3deshop.com/
past experience their slow at shipping but that was 2year ago
June 2, 2009 7:45 PM
I recently purchaced an I cybie with no battery I was wondering witch battery lead was the 12v and witch one was the 6v
June 3, 2009 2:46 PM
You can buy a new, mUCH better than original battery from StrikeALite in the UK.
http://www.strikalite.co.uk/viewproduct.asp?from=sresults.asp&prodid=382&cati...
their charger is good too.
June 3, 2009 10:34 PM
I was going to build a 2300mah for around 35dollars and neeed info on the battery leads to complete the battery help greatly appreciated
June 4, 2009 10:34 AM
Here you go... black = common ground, red = +12v, yellow = +6v
Derek Tombrello
April 17, 2010 7:50 AM
if anyone still need parts for the I-Cybie Dog let me know I have many many part including charging packs and docking stations very few power packs for the chargers though many many dogs I know it has been a few years since people were asking about them my Email is Whitefeather1006@aol.com thanks Dave
April 17, 2010 7:53 AM
if anyone need parts for the I-Cybie dog letme know send me a message I have many many dogs docking stations the little charger packs very few power packs for the chargers though. everything seems to work but I have no batteries to test them.
Discussion:    Add a Comment | Back to Top | Comments 1-25 of 31 | Latest Comment | 1 2 Next »
