ok heres the steps to extract your solar reflectors for Rq's Feet........
All fairly easy stuff guys ........Enjoy !!!!!!!
Categories: Robot Hacks and Mods Roboquad
I have found RQ has one big drawbak his feet wear if you use him on abrasive surfaces wich kinda limits the fun :(
I went on the hunt for things to work as feet and settled on the chrome plastic reflectors/diffusers from garden solar lights, they just slide on then u tape em up with electrical tape make sure u have reset your rq's stance before doing this or the legs will be uneven and make him veer one way when he walks.
The Conical shape of the reflectors allow him to walk on soft surfaces (sand etc) without sinking into it, and also allows for more agility in his walk so he turns etc better and can walk over obsticals better too the best bit is if the pads become uneven take him on cement and they will re-wear to be aligned correctly again depending on what you mainly make rq do of course. ill try to get you guys some photos of the feet pads and my modded quad.
ive been using solar lights from the cheap shops eg solly's u can typiclly get them for like 4 lights for $10-$15
Would you post a picture of the solar reflectors mounted on the Roboquad's feet?
Mudbugnla
Wowwee Bots: RoboQuad, Robotyrannus, RoboReptile, RoboPet
Tomy Bots: Verbot, I-Sobot
yet another view of my standard quad with feet augmentations made from solarlights
Another diff view of feet, you can see one of my led mods on the front of him too still needs to be perma fitted its only taped on atm lol
http://www.youtube.com/watch?v=e1jCASCqnEQ
this is the first vid with feet not glued/taped on
Here's another tip for you, to help your use of RoboCommunity.
You can embed your YouTube videos directly in the threads using the "youTube" icon in the post edit window.
Pretty good! Do they click when he walks on the tile? Tap-dancing roboquad!
Rovio rules!
The only problem is finding a bonding solution that wont void warranty, ive found electrical tape or aluminium tape best so far..... Any other ideas?
I never even thought of that !! Thankyou so much :)
Ill do that now and ill put a outdoors terrain vid on here so you can see the wearing patterns
In case something happens to your quad, I wouldn't suggest the use of hot glue. It can be painful to scrape off, and you'll scratch the paint trying to get it off. Of course the choice is yours.
J.T.
A begginer robofanatic!
The black spots is where its new wearing will occur this was after 2 hours on course cement
another vid soon
I'm sorta thinking hard on the hot glue idea too :(
What else could we use?
I've never had any trouble removing hotglue (off plastic), I find that if you pull gently, but persistantly, it peels right off.
Hot glue works great. All you need is a hair dryer to soften it up again, and it peels right off.
I use it for all sorts of stuff that needs to stay stuck, but allows me to dissassemble when needed.
Lol i cant find my hot glue gun :( will keep posting my progress as it goes guys
Ok results of hot glue prooves succsessfull !!!!!!!! The material RQ is made out of allows hot glue to hold on when required and will just peel str8 off when desired ....in conclusion my feet mods have been running on rq for about 2 days now with no problems ive noticed.....i found he wont fall over anymore either !!!!!!!
Photos of Feet for RQ will be up in 8 hours or so so u guys know what to look for
