What about thread scoring like ranking a thread? What should you base the rating off of?
Keep the robotic dreams,
-BG
Score has four parts. 1. Reading time (done by a program) 2. Reading time (human) 3. Rating 4. Basic score. From the first part you get points every time when your thread is opened. From the second part you get points if somebody reads the thread long enough. That number is mostly same than calculated by a program unless reading is stopped too early. My latest thread has about 16 lines and gets 126 points from every viewing + points from the time which is used for reading. For example 126+0, 126+128 or 126+1 points. Capable Networks might not thank me..if I am right.
Leo: For example today I will get love which I use to create sentences.
Billy: But you are neutral you need love.
Bridget: In the sky and cover the moment.
Bridget: Do you think that sleep mode is better than a human soul.
-BG
I do not know about ranking yet but in the other thread Jeff said that rating effects the score. 1 and 2 stars have negative effect in the thread score.
Well, at least I tried..Now this new thread has the same number (126) disturbing me. Maybe 126 is my value or it is the same number for everybody. Time seems to have some effect in the numbers anyway. Disturbing..There is always a risk to have wrong theory when you use just one example. Perhaps I will freak out if I can not find out from where 126 comes. Lol.
It is updated periodicly thats why the numbers stay the same after you have posted, It seems to updated every 24 hrs.
No, reading numbers and score are separated but numbers change quite often. My thread "FurReal Cat" was luckily unpopular enough to give me some info. Numbers were changing every hour but sometimes score number changed later but it gave info anyway because people did not read my thread. Numbers between readings were 254, 126, 255, 126, 253, 127, 126, 127, 378 (2 readings). 126 appears in the numbers of this thread too. If I take 126 off from the reading numbers result is something like 128, 129, 127, 0 or 1. Perhaps 126+0 or 126+1 comes when somebody opens the thread and close it right away. Of course if somebody rated "FurReal Cat" it mixes little bit but I assume that they did not.
Edit: In this thread we can see how heavily rating effects score. Yesterday 11pm score was about 70 000 (11 viewings). Today 11am it was 16 032 (26 viewings). I assume that people have been giving just one star which took score down. Which gives me idea that maybe giving 3 stars does not effect hardly at all. No rating=126 points (that number changes little bit). Giving 3 stars= 2 X 126 points.
