February 8, 2008 8:55 AM
Nocturnal said: Which is why a white car is cooler than a black car.
Only in a thermodynamics sort of way....
As mentioned there is additive and subtractive color changes done by substances. If you take two colors of paint, and mix them to create a third, it is subtractive tinting. Each paint tint absorbs different wavelengths (colors). If you take the same two colors, but this time as colored light, and shine them together on a white surface, you won't get the same tint that you got with the mixed paint. Shining two lights together is adding wavelengths to the mix, rather than the way paint mixes absorb additional wavelengths.
I learned about this in my physics classes, but there's lots of web references available that discuss it. For example,
http://home.att.net/~RTRUSCIO/COLORSYS.htm
What's this mean?
It means a black surface is a surface that absorbs all visible light wavelengths. As the fabric fades, and turns "grey", it is losing its absorbing properties and reflecting more of each wavelength.
Conversely, a white surface is one that reflects all visible light wavelengths equally well. If white fabric is washed with a red towel, and turns pink, it means that that the fabric has lost its ability to reflect all wavelengths equally, and that the red wavelengths are reflected more than the blue or green ones.
Infrared is not a visible wavelength. It's a longer wavelength than what the human retina can normally detect. Just because we can't see IR, doesn't mean that it doesn't get reflected and absorbed like other light. It works very much like visible light when it comes to absorbtion and reflection.
Dark black isn't necessarily the best IR absorber. It has to do with the nature of the fabric, too.
I have a charcoal grey chamois shirt that absorbs a lot of IR. It absorbs more IR than a much blacker tightly woven linen shirt.
You might ask how I know that, but you also might be sorry you did. The practical experiments involve certain public plumbing fixtures, and the IR detection they use to "arm" themselves for action upon your departure. Nuff said.
