Learn about scoring Forum's Raw Score: 51426.0
February 7, 2008 10:00 AM
Categories: RS Media
slqkyt
                                 I have connected the usb line into RSmedia with computer but still show "No robot found"message.
Discussion:    Add a Comment | Comments 1-7 of 7 | Latest Comment
February 9, 2008 1:17 PM
have you gone into robot settings and switched him in to   usb mode ??????????
February 16, 2008 7:36 PM
celticwar said: have you gone into robot settings and switched him in to   usb mode ??????????
The problem is I have swithced him into usb mode and used  2.1 suite and clicked  the download button">" but when I clicked the button.  No response that I can see on the screen.  I just want to download the C-3PO personality.  P/s help me!
February 16, 2008 7:37 PM
I have done all the needed procedure.  I think my computer lack of some files.
February 16, 2008 7:38 PM
P/s help me!
I like C-3po very much.
February 16, 2008 7:50 PM
Another problem is how I can exit the Usb mode. I have pressed all the button and the robot's hand-buttons but cannot exit the usb mode.
February 17, 2008 4:47 AM
at the bottom of your computer screen theres a panel where volume, connection ,lots of other stuff .there should be one that when you hover over it with your mouse ,say hardware click it diconect device .then try buttons .........
right connect bot to comp switch him on . comp will find him then lose him well mine does says fault .dont worry . go into bot settings switch him to usb mode , on . then your comp will find new hard wear .open with windows , files will come up then you can drag files into bot ie personalities like c3po ect ive got them all on mine .this is the only way ive been able to put music personalities photos on him . . hope this helps the only thing the softwear does is helps you put your own personalities +body cons ect .i never use it to transfer photos stuff ..
Discussion:    Add a Comment | Back to Top | Comments 1-7 of 7 | Latest Comment
