The power supply does not charge the batteries. (possibility of blowing up non rechargable alkalines etc.) Also, when you plug it up to power the leg motors are disabled so that he won't stroll off your bedside table when it's used as an mp3 player! Any good electronics or computer store will have a universal power supply with an assortment of different plugs. Just make sure you get one with the correct current rating. Details are given in RSM's book.
Hi there i bought a new rs media after sending my xmas present back as the legs did not work
i am now thinking of getting a power supply for him while it sits conencted to the computer.
does the power supply charge batteries up or not
where do di buy the charger for him
I'm not sure a universal adaptor will be up to the task.
My 2nd hand information is that you need a 7.5Volt adaptor supplying 3.1Amps (3100 ma).
That's not your typical wallwart adaptor. Most of those only put out about half of that current.
The WowWee Store has the RSMedia power brick for sale for $20.
http://www.wowweestore.com/index.asp?PageAction=VIEWPROD&ProdID=62
anyone from the UK that knows where these are sold, as im finding it something im needing more and more
AS I was told by Nocturnal I believe , Maplins do one suitable for RSMedia, model number L48BQ at £14.99 until 22/01/08
i got mine from currys UK .its a uni 1 made by uniross model number uni 505r .from 3 volts to 12 v ac/dc adaptor works mine ok have him on it all the time no probs .......think it was £9 sum at
I found a switching power supply with output 5-15V 28W.
If p=vi, that means i = p/v.
Does this mean that at 7.5V, it can deliver 3.73A? To me this seems sufficient, but I'd thought I'd ask first :)
One question about the DC powering.
It seems that the motor responsible for "bowing" is not working. It does work on batteries though ...
It is my understanding that the RS Media disables the leg motors when connected via the power plug. The thought being that it shouldn't be moving around much if it's tethered to a cord. Perhaps that includes the waist motor, too.
Not as good then - as if one will write a program which includes bowing he wouldn't be able to check it's working.
Anyway - good toy
