Just to let everyone know. I went to a good open space, no houses or trees, in a shool ground to really try out my Dragonfly and was amazing.
Got it to around I would guess 30-40 feet. Forget the beginners mode. I went straight to the pro mode and works a lot better. My trials inside and out in my back yard, was hard to keep it up in the air. Always lose altitude, but outside in the open would climb, could even do the trick of letting the throtle off, would sprial down, then full power control again, was great.
Found turning to sharp put the Dragonfly into a kind of seesaw swing, which would get worse with each turn, but let it run stright would correct itself. Turn less sharply and had full control.
One problem is the paint sees to come off easily and losing some paint allready.
Much better then the fake ones ever are and Flytech Dragonflys really fly. The fake one I had no luck at all.
Also tried with ribbon and without. With ribbon slows it down to I would say half speed or near, but with ribbon off do these things fly. The Dragonfly moves pretty quite and I think would be easy to get out of range if you where not careful. Twice I had to let the throttle go as I though it was getting to high, so might have gone out of range.
What would happen if it does get out of range? would it stop funtioning and just crash back down because of no power?
