Learn about scoring Forum's Raw Score: 132531.0
June 26, 2007 09:38 AM
  Moderator
The use of gas pressure to power machines has been around longer than electricity. We might be heading back in that direction.
There has been research in the use of air bladders, encased in a constricting sleeve, to approximate the behavior of natural muscle.
Here's one potential application of that in the news today.
http://news.yahoo.com/s/afp/20070626/...
Here's some background on the 50 year old concept.
http://www.imagesco.com/articles/airm...
http://www.shadowrobot.com/airmuscles...
Discussion:    Add a Comment | Comments 1-9 of 9 | Latest Comment
June 26, 2007 1:11 PM
But sinc air can be compressed is there any power in the robot that uses them when it comes to heavy objects.
June 26, 2007 1:19 PM
Compressed air is powerful enough to cinch up the lug-nuts on your car tires to the point where you can't remove them without a pry bar. That's with a machined metal mechanism, though, not a constricted air bladder.
I suspect that's what the mesh containment around the bladder is for. It gives a finite stop to the expansion of the bladder, and allows more PSI to be pumped into the air muscle without further expanding the muscle. That effectively tightens the grip without overexpanding the muscle.
If you read the initial news article, that pliant grasp is  being touted as a feature. It allows for the gentle touch needed to grasp an egg without crushing it, and then to pick up a heavy object with the same hand. The fingers are in the same grasping location. It is the variable air pressure that lets the grip be soft or firm, as needed by the situation.
June 26, 2007 1:22 PM
I've been reading about air muscles for a while at shadowrobot. this is really quite a fascinating concept, Eastercia.
To add to your extensive list of links:
I also like their picture gallery (of videos).
Dr. Susan Calvin: "To you, a robot is just a robot. But you haven't worked with them. You don't know them. They're a cleaner, better breed than we are."
June 26, 2007 1:39 PM
One of the attractive features of air muscles is that they closely parallel the function of natural muscle. They produce linear tension, and bunch up when "flexed". They have stretch, or give, when lightly flexed, but are able to lock up more tightly when clenched hard.
 Depending upon the specific application, the use of compressed air for motive force can be preferrable to the use of electric servos or motors. The air muscles won't produce nearly as much RF motor noise as our more familiar electric motors do. That can mean less shielding for the electronics that might be susceptable to RF noise.
 The air muscles are reported to be much quieter in operation than an electric servo. I suppose that depends on the engineering of your air supply and vent tubes.  A pneumatic snake would seem more natural as it hissed across the floor.
You could conceivably have a large air tank in the robot to supply its working pressure, with a compressor that cycled on and off to keep the tank topped off. That's pretty much how the compressor I use for my airbrush works.
The other technology in use for the big bots is hydraulics. It's the same technology that powers backhoes digging ditches. Lots of power there.
I worked with a Cincinatti Milicron T3 in college. That hydraulic powered chunk of iron could hold a cement block and position it anyplace, and in any orientation, within it's workspace with an accuracy of 5 thousandths of an inch. That is the type of robot you typically see on manufacturing lines assembling car bodies.
June 27, 2007 9:49 AM
Air muscles have been around for a while. I believe that pnumatics is used a lot in animatronic displays, because its cheaper and easier to maintain than electronics. Its also quieter than electronics, but only because they can put the air compressors elsewhere. With the air compressors being elsewhere, they can also fit more actuators into the same space.
The bigger the air tank, the larger the robot needed to move it, the more compressed air it needs to move. I believe the law of diminishing returns is involved. I suspect your aircompressor for your airbrush would have difficulty supplying enough air to move a robot (its not really a question of pressure, more of CFM). You'd also need to power the air compressor, which is more wieght. Overall I suspect its less efficient than using electronics.
I've yet to meet an air compressor that doesn't make a lot of noise.
Air muscles have their uses, but I don't think they are going to be replacing the electronic motors in robots any time soon.
June 27, 2007 10:14 AM
Those are valid points regarding the weight of a tank, and noise of refilling it. My compressor is a general purpose one, not a dedicated airbrush unit. As such, it is big, heavy, and noisy. I leave it in the storage space and run a hose to the work area I'm using.
There are many types of robots. Not all of them need to march about untethered. Every lab space I've been in has compressed air supply lines.
An air powered, pool cleaning robot might be a better fit than one that uses electric servos. Yes, I realize there are likely still electronics needed to control the air muscle valves.
How about an air-bot that attaches to the hull of your boat, and scrubs it clean while it is sitting at the dock?
A garage-bot, adept at the use of air tools to work on a car, would likely have a ready supply of compressed air, too.
June 27, 2007 10:25 PM
:) I also have a general purpose air compressor, which I use in odd moments to attempt really bad airbrushing.
Pnumatics under water is not such a good idea, air compresses, water pressure will be an issue the deeper it goes. Though near the surface it won't be such a problem (Thought stable boyance could be a problem, shifting all that air around). Undewater, hydralics are better.
You have a point about not all robots needing to be mobile, but most of them would probably be hydraulic rather the pneumatic. For cleaning the pool, you'd probably be better off with a form of hydraulics. Since most pool cleaning involves a hose connected to a pump, you'd have a ready supply of negatic pressure.
August 30, 2007 8:04 AM
Here's a nice example of the air muscles at work, as found on gizmodo
http://gizmodo.com/gadgets/robots/rob...
August 30, 2007 1:37 PM
This is a great example of air muscles at work MrScott. One day, One day. We will get there.
Discussion:    Add a Comment | Back to Top | Comments 1-9 of 9 | Latest Comment
