You need to install Netbeans and the Netbeans mobility pack for CLDC (not CDC, in case you installed that one). Both are available from www.netbeans.org and install automatically. Afterwards, if you follow the instructions given in the RS Media Java SDK docs, the additional Netbeans modules should work.
Hi!
I have installed the netbeans ide 6.0 and the mobility pack is also there in it. according to the instructions in the robot control development module document, i need to go to the update center in the tools menu, but there isnt any such option. so i went into plugins, and i selected the downloaded plugins tab, and tried to install the modules that came in the cd, but then, it gives an error, which is this.
Missing required modules for Plugin Humanoid Robot Control Library:
module org.netbeans.modules.kjava.j2meplatform > 1.1.5
module org.netbeans.modules.kjava.j2meproject > 1.1.6
please let me know what i should do. i am working on windows vista. and i have downloaded the ide and mobility pack about 5 times now, but stil the problem exists.
thank you
I have the same problem. I am running Windows XP. I installed JDK 6 Update 3, then Netbeans Mobility. I get the same error.
Same problem. Who can help with this? How do we get Netbeans 6.0 working? Thanks!
I'll try the NetBeans 6 install (I'm on XP SP2) but I already have NB 5.5 up and running, so I don't know if that'll make a difference.
Rovio rules!
Yes, that's the thing, something changed in the 5.5->6.0 version update so it no longer works... Unless you're saying you put 6 on top of 5.5 and now 6 works?
Rovio rules!
Who wrote the libraries? Sun or WowWee? Can we contact anyone about this? I really don't want to install both 6 and 5.5 on my laptop, and I need to have 6 on for work compatibility.
Or maybe just copying the 5.5.1 jar files would suffice. I think I'll try that out.
The libraries came from Sun and as I understand, WowWee is running into roadblocks with Sun so not much is moving there. I have the same symptoms with NetBeans 6, no solution in sight. I still have 5.5.1 installed and operable at the same time on my machine, but I don't see any way to import the modules. Sorry guys, I'm not much help!
-Scott
Rovio rules!
If you are interested in a better PC Suite Sotware also please suscribe to the PETITION for a better software !!!
Horia Pernea
http://www.roboticage.eu
