Learn about scoring Forum's Raw Score: 202419.0
November 24, 2006 11:21 AM
Categories: RS Media
england_pete_73
I recently purchased the RS Media and have to say it really is fun to use.I'm not too happy about the battery life though.Pretty expensive to keep it running.So I bought a mains adapter for Robo.I made sure it's the right voltage 7.5 and it's all the right connnections.But he seems to cut out after a while and reboot himself.Am I doing something wrong.Do I need an official mains adapter for the Robot?If so,where could I buy one? Are rechargeble batteries any good with the Robot? Many thanks.
Discussion:    Add a Comment | Comments 1-7 of 7 | Latest Comment
November 24, 2006 10:36 PM
Check the current rating for the mains adapter, it should be 3.5amps or above.
November 27, 2006 3:01 AM
I have also recently purchased an RS Media. I did not even bother about purchasing "normal" batteries, just spent the extra and purchased rechargeable. Only played with it for about 1/2 hour so far, seems to be fine.
November 27, 2006 2:41 PM
I think I'll purchase rechargeable batteries.As batteries don't last so long it's probably better that way.Thanks for the info guys. Laughing
November 27, 2006 11:55 PM
Hi, I purchased rechargeable but the mistake that I made was buying a very low mA/h rating. I need to recharge my baterries after every hour or so. The cost factor is always an issue, the higher mA/h rated batteries are much more and again you land up spending a whole lot of cash for batteries as RS takes a good few.
Can they not come up with a build in battery pack that we can charge from the wall socket, I am sure that is not very hard to buid into the robo. We should suggest this to WowWee
November 28, 2006 1:44 AM
I'm sure it has occured to them, since people have been asking them if its possible to use rechargeables all the way back to the original RoboSapiens. I personally think its a cost issue. building in rechargable batteries and supplying a charger would increase the overall cost of the robot. Though they may be heading in that direction, since the RS Media can be powered externally (thats only a step away from charging batteries from external power, and a possible hack someone might want to try).
June 16, 2008 1:09 PM
While my RS Media robot is pluged in charging device, all time rebooting right after booting procedure is complited. In a battery mode booting going normaly.
Adapter 7,5 V. Without batteries in legs.
Please help.
June 16, 2008 3:42 PM
It sounds like your Adapter isn't able to handle the current load. WowWee recommends as 3.5amp power pack.
Discussion:    Add a Comment | Back to Top | Comments 1-7 of 7 | Latest Comment
