rs media problems! cant connect to pc
6 posts / 0 new
ElleBayar2011
ElleBayar2011's picture
hi, im new here, im after some info before i go mad!,
i have got 3 rs medias all 3 of them i cannot get to connect and be recognised on my vista 32bit pc, it is the version 2,4 media suite, when it does recognise it in "my computer" i cannot format it or anything, just crashes the damn pc over and over, on all 3 of the medias!!, i have them powered up by the ac power, in usb mode, then open media suite and nothing, how can i format the damn things!! am i doing something wrong, in the connection??, it isnt rocket science,  cannot find any related info anywhere:(,  please can someone offer any help,
thanks, i look forward to positve news, before i do something i may regret
FreddyA
FreddyA's picture
Hello ElleBayar2011, welcome aboard! I do remember having problems with the sd being unreliable in vista. Are you going into usb mode before plugging in to the pc? Are you using a 1gb or less sd? Have you tried a different usb cord? I assume you dont have a diffrent OS to try on so maybe start the suite in xp compatablity and as adminnistrator.
Freddy
ElleBayar2011
FreddyA said: Hello ElleBayar2011, welcome aboard! I do remember having problems with the sd being unreliable in vista. Are you going into usb mode before plugging in to the pc? Are you using a 1gb or less sd? Have you tried a different usb cord? I assume you dont have a diffrent OS to try on so maybe start the suite in xp compatablity and as adminnistrator. Freddy
hi freddy,  i didnt have an sd card in them when attempting to connect them?,  i go to usb mode after i plug the usb cable in and yes its a 1gb sd ive tried putting the sd card in them all but to no luck, yep to a different lead, i wish i could run it in xp compat mode but the option is not there on right click!, tried version of suite that came on cd-rom and 2.4 nothing,  also when it is showing as a removeable drive i right click and select format and nothing happens? can you offer any more help?
thanks
FreddyA
FreddyA's picture
Hi, try going to usb mode first before (not after) connecting the usb cable. So he will say "tether attached" in usb mode, then plug the usb cable to the bot and to the pc. To get to compatability tab right click and on the menu, click properties then find the compatability tab.
Freddy
Tareq
Tareq's picture
me too , Same problem exactilly ..,
But Mine give me ( usb device is not recognizable ) so i replug the usb many times but no luke ,
I tried to plug the cable (before/after) boot the robot (also before/after) make it in the (usb mode)
and once it successfully connected ( 10% of the times i try)
it keeps unpluged/pluged every 10 sec for example
so the editing suite dosent work at all ...,!!
any ideas ?
I post the details at this post also but no one reply :
http://www.robocommunity.com/forum/thread/12196/Vista--RS-Media--and-USB/
Thehaag
Thehaag's picture
Wowee give the worst support, trying getting new parts for the robots yet alone drivers for a $900 robot. Never again will I by from this company......
