Hey Peter,
a very useful article but, can you explain the part of the battery section again (lame joke sorry)
Anyway, i am gona try it out as soon i get my hands on the remote.
bastelmeister
Control your WowWee Femisapien from a Robosapien Remote
Categories: Femisapien Robosapien V1 & V2
You cam use the WowWee™ Robosapien™ remote controller (included) to control Femisapien.
The remote controller requires 3 x “AAA” size batteries. To install the batteries, do the following:
1. Open the battery compartment located on
the underside of the remote controller using a
Phillips screwdriver (not included) to remove
the screws on the battery compartment cover.
Insert the batteries according to the diagram.
2. Ensure that the positive and negative polarities
match the illustrations inside the battery
compartment.
Replace the battery compartment covers and
3. replace the screws using the screwdriver. Do
not over-tighten.
Shift levels
The remote controller has 3 shift levels. You can change levels by pressing the
Select button. The LED on the remote controller indicates the shift level as explained in Table 1 below.
IMPORTANT: After you send a command the remote controller will reset to Shift
level 1. That is, if you require Shift level 2 or 3, you need to select the shift level each
time you send a command.
Remote controller functions
The control functions for each level are explained in the following table (Table 2).
NOTE: Right refers to Femisapien’s right and left refers to her left.
