OUR NETWORK:TechLore Sling Community MyOpenRouter MediaSmart home Pogoplugged See all... About UsAdvertiseContact Us
WowWee Rovio Review and Unboxing
WowWee Rovio at RoboCommunity
Rovio by WowWee
I'm sure you've heard the buzz about WowWee's new robot, the Rovio. Billed as a "mobile webcam," the Rovio connects to your local network via Wi-Fi (802.11b/g) and is controlled via a web-based interface served directly from the robot. Rovio has the TrueTrack Navigation System built in, which allows you to save various locations, allowing your robot to automatically navigate itself to a specified location. Should the battery run low while Rovio is "out and about," this same system allows Rovio to return to it's charging station for a refill.
Like many, I've been wanting to get my hands on one since I can remember first hearing about it, and now I have. Read on for the unboxing photos, action shots, and my experiences using this slick little 'bot.
Arrival and Unboxing
It all started on a quiet, sunny, Southern California morn. There I sat, minding my own business, when suddenly... there came a rapping, rapping, rapping at my chamber door.  Unsure as to what may be causing this AM disturbance, I convinced myself 'twas but some early visitor, only this and nothing more.  Gathering myself I approached - here I opened wide the door, and quoth the FedEx guy, "Rudolph? Sign here please."
Okay, that was pretty bad. Truly sorry about that. I'll make an effort to be less dramatic for the remainder of the story.
Having signed off for the package, I accepted a rather dull looking cardboard box. Bringing it inside, I realized my other robots were quite keen on discovering what this new treasure could be.
Before I knew what was happening, they had pushed me off to the side and were opening the package!
It was a new Rovio.  And there was much rejoicing!
Okay, that was pretty bad. Truly sorry about that. I (and the robots) will make an effort to be less cheesy for the remainder of the article. Those responsible have been sacked.
Inside the Box
Armed with two energy drinks, a pocketknife, a screwdriver, wire cutters, a hammer, and wondering if I'll need a blowtorch, I began to open the box. The first things I found were the manual, CDROM, and a USB cable, sitting on top of a styrofoam clamshell packing block.
"Interesting..." I thought to myself.
Seperating the two halves of the foam I found the Rovio, battery, and two pieces of the charging dock, all in seperate plastic bags, well fit into their respective cavities in the foam.
"But... Where are the wire ties? Or the hot glue?" I wondered.
Nope, not here. I believe that a person could liberate a new Rovio from it's packaging in less than twelve seconds without destroying anything.
Assembly
The manual makes it fairly clear how to set up the hardware. From my setup, and talking with others, there are a few points to pay attention to:
  • Make sure the mast is aimed forward when you install it on the dock, it seems it is possible to install it backwards.
  • When you aim the beacon at the ceiling, make sure the two red dots are parallel to the base. If they're perpendicular, Rovio will act fairly confused and have a hard time navigating its return to the charging dock.
  • You may want to attach the base to the floor in some way. I've found that it slides around fairly easily on linoleum when Rovio is docking. Even on carpet, some method of attachment is handy, as Rovio will occasionally run over its base while driving about (even with IR Radar turned on) and move the whole thing out of alignment. If you have a permanent location for the dock, you may want to tape the beacon lens in place as well, it seems to jar easily, moving the beacon out of alignment.
  • When everything is plugged in and the battery is installed in the robot, make sure the robot is turned on when you place him in the dock. It seems Rovio will not charge unless its switch is in the on position.
Now that everything is plugged in and charging, it's time to take a break. Mostly because Rovio will want about two hours to charge up the battery for the first time. You'll notice the blue lights around the perimeter will turn solid when the charging is completed.
Rovio Software Setup
Again, the manual makes it fairly clear how to configure the Rovio. Insert the CD into your Windows computer (XP or Vista) and follow the prompts.
You may find when plugging the mini USB cable into the robot that it takes a little more force than you're used to putting into a cable. When finished, it takes a similar amount of force to remove it again.
Just for the sake of messing with things I also tried connecting to Rovio with the Windows "Advanced" instructions. Following the steps in the manual resulted in a quick and easy Ad-Hoc connection, allowing me to complete the configuration of my wireless setup via the settings menu.
First Impressions
While I used Windows XP for the setup and initial uses of Rovio, I just couldn't bring myself to keep using Windows.  Happily, Rovio seems to function just as well under Linux with Firefox as it did on Windows. The two way audio feature only works with Internet Explorer, so I had to give that up, otherwise things seem about the same.
As mentioned, Rovio navigates via a beacon that is projected onto the ceiling from the charging base. Unfortunately, my house isn't well designed for ceiling based navigation. The living room has vaulted ceilings, and the dining room has a beam running lengthwise through it, which seems to obscure Rovio's line of sight. This has, however, created a great source of entertainment in watching Rovio try to navigate to places near the edge of its view of the beacon. I will definitely be buying additional room beacons in the future so it can more easily visit other parts of the house.
From time to time while auto-navigating to a waypoint Rovio will become hung up on something, like the corner of the throw rug, or the transition from kitchen floor to carpeted dining room. You can click the Stop button and take over driving manually, or wander over and pick it up and re-orient it.  Turning off Rovio's IR Radar seems to help with these little obstacles.
The headlight mounted in Rovio's "chest" illuminates a small spot on the floor directly in front of the robot.  Some people might like to see more light, so I expect to make an attempt at adding additional lighting for the Rovio... Keep your eyes peeled for more information on RoboCommunity!
The Moving Picture
Here are a couple videos I took of Rovio doing its thing. You may notice some interesting tidbits here.
  • When you tell Rovio to go to a specific waypoint it will locate the waypoint stored before that one and navigate from there.
  • Large obstacles, especially shiny ones, seem to confuse the Rovio a bit during auto navigation.
  • You'll be surprised how amusing Rovio's "Happy Dance" after docking actually is.
The End
All in all, I find myself impressed with the Rovio. The ability to control it from almost anywhere definitely adds a certain groovy-ness factor.  It certainly didn't take long for the little robot to endear itself to the family, we are all guilty of talking to it more than we should (eg "Well, go around it!" or "What happened?" or "Ha! You kinda missed a bit, didn't you?")
It certainly is a refreshing change from the walking variety of robot that is so prevalent in my home, and I hope to enjoy it for some time to come.
Learn More About the WowWee Rovio
Talk About the Rovio on the RoboCommunity Forums
Tags : northstarreviewroviounboxing
Discussion:    Add a Comment | Comments 1-25 of 50 | Latest Comment | 1 2 Next »
October 6, 2008 12:03 PM
Love the picture with Robopet scratching at the box. Nice to see other Robosapien RS media owners like you, nocturnal, crmfghtr, and myself.
Robodance 5 - Rovio over Skype with Voice Control
  • No more router setup hassles
  • 2 way audio on any system
October 6, 2008 12:37 PM
Any robot review that involves Monty Python, even if it is only a fey senteces, is a winner.
October 6, 2008 12:54 PM
I'm so, so, so jealous! Nice video!
www.teachtechno.com
October 6, 2008 1:41 PM
How did you get your Rovio so early?
October 6, 2008 3:35 PM
Do you need to buy a beacon for every room the rovio can enter?
October 6, 2008 3:48 PM
costap said: Do you need to buy a beacon for every room the rovio can enter?
Yeah, pretty much, unless it can see the beacon from the other room. Rovio can navigate my living room, dining room, and kitchen okay with the Dock in about the middle. It can only get about 5 feet down the hallway before the signal is lost.
I've not yet heard price or availability of the individual beacons. I'm looking forward to getting one though so I can move the Dock off to a corner somewhere.
I believe it'll remember 9 different beacons, and remember which one is closest adjacent.
Watch out, don't step in the anthropomorphization.
October 6, 2008 3:53 PM updated: October 6, 2008 3:54 PM
However, that's only for self-guided navigation. If you want to explore manually (driving Rovio yourself using the web interface remotely), you can drive wherever you like as long as you have a strong WiFi signal. In other words, Rovio should be able to go to every part of your home where you can connect reliably with a PC or laptop, while driving under manual control. The TrueTrack beacon signal is not pertinent to the manual driving range, only the WiFi signal.
October 6, 2008 4:10 PM
Good point roschler, thanks for bringing that up.
It is also possible to connect to it without a wifi router, via an ad-hoc connection from (for example) a laptop. Then you can manually drive Rovio anywhere at all :)
October 6, 2008 5:00 PM updated: October 6, 2008 5:01 PM
One other tip. Remember when manually piloting your Rovio outside the TrueTrack range to reenter the room with the primary beacon before you sign off, execute a Go Home operation, and then sign off. Trying to self-dock manually without rearward facing vision would be a real challenge. Fortunately it is not necessary.
October 6, 2008 11:39 PM
Haha, that was great! And your right, you cant help but feel even this robot has a personality. Love the silent film slant to your film, applause!
October 7, 2008 8:11 PM
i love how the robopet fell over when the box opened lol.
i actually have two of the separate true track beacons, but no rovio :(
October 7, 2008 8:20 PM
Do tell, where did you get the extra beacons?
October 7, 2008 8:24 PM updated: October 7, 2008 8:27 PM
from wowwee of course. they posted very fast. but they did warn me they were in testing mode still and may not work correctly yet. (this was a while back)
i should point out that I work for a company that is involved in telepresence and I plan on demonstrating rovio to customers as a mobile telepresence example.
October 7, 2008 8:40 PM
Really... I've checked the wowwee store a couple times lately (today even) and not spotted them. Really looking forward to getting my Dock out of the middle of the room :)
October 7, 2008 8:48 PM updated: October 7, 2008 9:05 PM
from wowwee not the wowwee store...they are not available as far as I know.
definately a vital addition to the rovio setup though. hopefully they'll be out soon so i can get some more!
October 7, 2008 11:33 PM
Ah, gotcha.
October 8, 2008 9:58 AM
The only downside to the movie soundtrack is that we cannot tell how noisy the little beastie is as it trundles about.
Are the drive wheels and mast control noise on par with the typical WowWee robot motors, or something a little more subdued?
ScottE -- collecting and building robots for 40 years - details in profile
October 8, 2008 11:22 AM
For you, MrScott;
The parakeet is pretty loud in this clip. She's sitting about 4 feet to the left of the camera. The Rovio Dock is about 4 feet in front, and the far point (the Chair) is about 10 feet.
My hearing is pretty well whacked, so I'm a really poor judge of comparing the noise level to something. I guess I'd say the neck motor is on par with my Media's arm movement. Drive noise is similar to a couple of the toy R/C cars my son has, with a bit of extra noise from the omni wheels (they click a bit as the ten little wheels slide on their axle).
October 8, 2008 12:35 PM
Rudolph, what are you using to record you Rovio videos? I tried Camtasia studio which usually works fine but got very choppy video.
October 8, 2008 1:07 PM
These vids are just from my digicam, edited with Kino (and sometimes Cinelerra) then converted to wmv with ffmpeg.
I've not yet found a solution for capturing Rovio's video. I don't remember what I tried with windows, and I tried everything in the Ubuntu repos. Hardy seems to have broken most screencasting programs, based off all the forum posts I read trying to make it work... The windows progs I tried always ended up really choppy too. When I try to save the rtsp stream to disk with VLC I get a video file, but none of my editors can seem to read it.
October 8, 2008 7:49 PM
thast great it has very robotics sounds i love it thanks for posting the vid with audio.
October 16, 2008 10:36 AM
Did you install the two LED lights by the camera yourself? 'cause I don't see them on other Rovio... its a great idea tho.
October 16, 2008 11:57 AM
CY said: Did you install the two LED lights by the camera yourself? 'cause I don't see them on other Rovio... its a great idea tho.
Good eye. Stay tuned ;)
October 20, 2008 8:14 AM
The rovio is still not available in the UK.
Any ideas when we'll be getting it across the pond?
October 20, 2008 10:04 AM
Marc123,
Red5 should be getting theirs around November 1st and I'm pretty sure they will be first.
Discussion:    Add a Comment | Back to Top | Comments 1-25 of 50 | Latest Comment | 1 2 Next »
