Generic Robot Base with RSV2 Attached (Page 1 of 21)
Categories: Robot Hacks and Mods Robosapien V1 & V2
Generic Robotic Base with RSV2 Attached
by RobosapienV2_4mem8
(Keep up with my work on the Hacks and Mods Blog.)
Hi Guys, I (RobosapienV2-4mem8) thought I would put up some photos of a weekend project making a robotic base. This project would be a good exercise for members and others in constructing a simple robotic base. The base is constructed of alloy, the wheels from an R/C toy and casters which were lying around, some parts have to be made. Motors and motor drivers will vary depending on what you have or install. This is for the basic frame only. I have included the finished robotic base photo. The rest of the details on how to build it will follow underneath.
Since this article was started it has progressed into something much larger and therefore it is now NOT a weekend project, It started out as a simple robotic two wheeled base as you will see from the start of this blog, but has moved onto a bigger project. So, the first 20 chapters in this saga are published here, but to keep up with the continuing saga, visit the Hacks and Mods blog.
Table of Contents
Introduction
1. Frame Assembly
2. Wheel Assembly
3. Installing the Motors
4. Fitting the Casters
5. Installing the Motor Controllers
6. Installing Some of the Electronics
7. Making the Perspex Base
8. Installing the Batteries
9. Installing the Electronic Brains
10. Installing the IR Detectors
11. Installing Micro Switch Bump Sensors
12. Installing the Distance Sensors
13. Fabricating Frame
14. Installing Flexi Glow Rods
15. Watch the Video
16. Mounting RSV2 on Base
17. Modified RSV2 Sensors
18. Shoulder Laser Cannon and WIFI Camera Sight
19. Fabricating 12v to 9v, 6v and 3v for the Laser
20. Connecting Power Supply to the Unit
21. The Saga Continues...
